I now have an RPM based notch filter enabled using ESC telemetry from bi-directional Dshot.
I’ve been looking through the wiki and past threads on this forum to find out if I should make any adjustments to the various filters now that the rpm based notch filter is working.
There has been a lot of discussion on past threads regarding filters. For example:
Given this subject has undergone some significant changes and improvements in the last 3 or 4 years, I wanted to be sure I had the most up to date guidance.
The wiki indicates AutoTune adjusts only two filters: ATC_RAT_YAW_FLTT and ATC_RAT_YAW_FLTE
Is there any more guidance available for setting filter values now that I have an RPM based Notch Filter enabled?
