CURRENT ISSUE: GPS: No GPS
PREVIOUS ISSUES: GPS: No FIX and Unhealthy AHRS bad heartbeat
Currently facing the issue GPS: NO GPS. One moment my GPS will be working properly and showing 7 sats. Seconds later it wont have any GPS signal at all. Mission planner will say NO GPS.
Last time I was here, I had the issue of GPS no FIX. the GPS took forever to fine satellites, but eventually I was able to find 7. Unfortunately I ran into the error of Unhealthy AHRS.
Another community member recommended I update the Navio and Arducopter. We ended up reinstalling the navioOS and then did the appropriate firmware update and setup for arducopter. We did the mandatory hardware calibrations and now we are presently facing the GPS. NO GPS issue.
When Mission Planner reports NO GPS it means there is no gps. That could be a defective GPS or a bad connection to the GPS. No fix means it has not received enough satellites or a good enough reception to get a 3D fix and establish location but it does “see” the GPS. In other words it is communicating with the GPS, there is just not enough data to establish a fix.
Do you have USB3.0 connections on the Navio? Those are known to interfere with GPS reception. How far apart is the GPS receiver from the rest of the electronics?
I’m aware of the difference between No gps and GPS no fix. I was just wondering why one moment I’m getting satellites and the next moment it can’t pick up my GPS. Before I reflashed my navio the GPS error was simply no fix now after I reflashed the GPS error is even worse.
You clearly have a intermittent problem. Bad cables or a problem with the uart in the GPS or flight controller. Seems like the cheapest troubleshooting measure would be to replace the cable first.
GPS module is part of Navio2 card. There is an active antenna with connector. Even without that antenna, when GPS configuration is fine, GPS status is 1.
If GPS status is O (No GPS), it is a configuration problem (config or bug).
If it is integrated then it is harder troubleshoot without a complete replacement unit to swap out.
Linux makes it also harder because there are fewer people that use it.
Understanding that this is an old post, and possibly unrelated, however I hit the same symptoms.
The “data” view shows “NO GPS”. However hitting [ctrl+F] to bring up the “temp” dashboard, I can see that the GPS is listed in green as “En Present Ok”.
Opening a QGroundControl and watching the sensor output, the issue was that there was no satellites locked in. Once that occured I went back to Mission Planner and now see the GPS online.
