GPS NO FIX / test done outside with a clear view ( aerodrome space)
Hello everyone ,
I ve tried my pixhwk cube outside , in the same condition I ve been told last time , I changed YAW by STCOUNT but It didn t work :
Thank you for your advice in advance
Add your parameters, and which serial port you’re using.
Also which GPS unit
GPS CONNECTED TO CAN 1
Serial port , I click on AUTO so it leads directly to COM9
Have you gone through DroneCAN setup?
If you can add a picture of the aircraft it might help to make sure there isn’t something interfering with the GPS receiver.
Thank you for your fast reply , here it the picture of DRONE CAN , I did update to the 127 ID
for the moment I did not plug my pixhawk with an aircraft or a receiver FRSKY that I Have, do you think that s the reason?
