GPS Module Suggestions
Any suggestions for GPS modules that have similar (or better£ performance to the Holybro M10 but may cost slightly cheaper?
Would appreciate any suggestions (and links/stores if possible for Canada).
Epic has the Holybro M10 for $40CAD. They’ve got a bunch of other smaller modules for $30, but for the money I doubt you’ll get much better. As the physical antenna get’s smaller the performance will go down. I’ve used the holybro M10. It starts up fast, the HDOP is always low, and the compass module in it hasn’t given me any grief. So unless you’re chasing grams it’s a solid bet.
For contrast I installed a Flywoo GM10 Nano today. Great for a sub-250 build I’m working on, and checks the right boxes for a compass/gps module. But let’s just say I won’t be using that module for anything requiring real accurate positioning.
Oh really? I was only able to find the $66 one. Is the one you saw, like a different version of the same module?
Yeah, I get what you mean. The size of the antenna is ofc crucial. I’ve heard good things about the HGRLC M100 Pro but I just can’t find it in stock anywhere, so I guess the Holybro it is.
Try that one. Cleaner build than those big round ones.
Or this: Micro M10 GPS (With Case) – EpicFPV
Same GPS, just with the case.
Oh I didn’t even peep those. Same performance, I’d presume, just a smaller form factor. Is there any benefit going with the case other than just some protection?
Easier mounting, maybe. But yes, same performance.
much love, i appreciate that. save a quick little buck
