Have the settings for GPS disabled, optical flow enabled, and only EKF2 enabled.
What is it that I am doing wrong ? (Do I need to provide anything further to diagnose at a first look ?)
Hey @amilcarlucas !
Just happened to read this from chatGPT :
'The EK3 (Extended Kalman Filter 3) in ArduPilot does not directly support optical flow navigation in a GPS-denied configuration. The EK3 primarily focuses on GPS-based navigation and state estimation, whereas the EKF2 (Extended Kalman Filter 2) is the module designed to handle vision-based navigation, including optical flow sensors.
A bit unsteady with this now. Please help me understand.
I am getting this errorpersistently with EKF3. IS there any resource online, that I could methodically follow to get this configuration in SITL ? Or could you please illuminate on what needs to be set right here ?
What an awful use case for ChatGPT! Don’t even bother asking ChatGPT such technically specific questions. At best, you’ll get a quote from an outdated website. At worst, it will make just enough sense out of nonsense to cause you to trust it…and crash your copter.
Again, it’s a bad use case. LLM GPTs are trained on historical data to give you a pleasing answer - essentially, they tell you what you want to hear based on data that’s only as recent as the last training cycle and what amounts to a statistical analysis of word frequency and order, given a context. They are not bound by fact. There are amazing use cases for the technology, but asking highly specific, technical questions is not one of them. I would never configure ArduPilot parameters based on a ChatGPT query.
A broader question, like asking it to explain how EKF works, might be a better use case, but the response should only help frame further research rather than being taken as 100% fact.
I often use it to write code snippets (or repetitive declarations, like array literals). It often excels at that, but I never ask it to write code for something I don’t understand, and I almost always refine the result to some degree. It tends to be (predictably) TERRIBLE at arithmetic.
