I just wanted to comment on GPS blend option.
I have been using it (2 Zubax UAVCAN Gps) on our test machine for 200 flights (around 100 hours). It just worked reliably, never a problem and position has never been so stable and accurate in any Gps positioning mode.
Thank you to the team for a great option that looks like is not used much but it should because it improves greatly Gps performances and reliability in my opinion.
Thanks for the feedback. I also think the blending feature is really good but under used feature. It’s a very cost effective way to improve position accuracy.
Randy thanks for your reply,do you no when the mission planner/ardupilot will be available roughly for using the can bus with the here GPS please and thank you
I have wanted to do dual GPS for sometime.So perhaps it’s time.
I have a Zubax GNSS V2 on the canport…well once I get it back as it’s appears to not be working. that said, I also have a M8N so I am wondering can I use this combo for Dual GPS.
Speaking from the rover side of things, I completely agree, the GPS blending feature is phenomenal. The positioning accuracy I’ve been seeing with a UBlox M8N and older generation 6M is very robust. In open parking lots I’ve been getting close to +-1m accuracy just with blending. Thanks for all the hard work that went into this feature!
I echo your comment Corrado_Steri
I have been using the dual GPS option for some time ( using best signal ) and I get
good positions. I use dual SE100’s on pixhawk 2.4.8 and pixhackV3.
