Good tuned quadcopter vibrates quite a bit at loiter only
Hello again guys,
yesterday i asked i question about my a high autotune value here:
https://discuss.ardupilot.org/t/autotune-succeeded-with-pitch-angle-p-out-of-range/98069/2\
Mr. andyp1per, told me that everything was ok so today it was the day for checking my new tune.
Stabilize, Althold are pefrect, the copter seems tuned quite well, a day and night difference before autotune.
BUT Loiter is not good, copter oscillates quite a bit, on roll axis mainly (as i can see). You can also hear the motors make that vib sound… I’m afraid to try other gps enabled modes with that behavior… Something is wrong…
I searched about this issue but i’m not sure what to do. Could someone please have a look at my dataflash log and give some guidance please?
I uploaded the file here: cloud.metal.ntua.gr
Thanks in advance
please autotune accroding to these refrences
i don’t understand your comment.
All necessary steps to manual tune and autotune the drone were followed. It flies perfect except in loiter. Did you ever had a look at the log? I don’t think so.
This craft is underpowered/overweight.
MOT_THST_HOVER,0.4968849
This could be trouble when a higher thrust demand is required. You will know when you receive Thrust Loss errors when the outputs max out.
maybe, but i dont think that this is related to the loiter oscillations.
moreover the problem exists with or without the camera payload.
Maybe true but you should have addressed this thrust/weight issue before getting very far.You will have to re-tune it anyway after it’s corrected.
i found this:
tomorrow i will try halving PSC_POSXY_P and PSC_VELXY pids and see. I will report back the results.
Solved. Lowering PSC_POSXY_P and PSC_VELXY pids by 60% solved my issue.
