GMap not loading in another Form
Hello everyone!
I’ve run into an issue: I want to move GMap to a different Form, but the map doesn’t load.
When I launch the application with MainV2, everything works perfectly — the map loads and functions as expected. However, when I try to move GMap to another Form, the map simply doesn’t display.
Could this be an initialization issue or something related to calling methods at the wrong time? If anyone has experienced a similar problem or has suggestions on how to fix this, I’d greatly appreciate your help!
Thanks in advance! :blush:
