Getting higher velocity measurement precision
precision of velocity estimates “vx”, “vy”, “vz” seem to be limited to 2 floating point digits (attached screenshot from Mission Planner below). Is there any way or any parameter I can use to achieve higher precision?
It is important for me, because I use the measurement for custom algorithm, which suffers from signal spikes due to velocity estimate quantization error.
Screenshot_20231001_154942
Those are just the digits displayed in MP
The mavlink message has full floating precision
Than you for your reply!
Actually, I was observing two digits precision after receiving MAVLink message. To make it more explicit I was using dronekit to acquire velocity readings. Your replay was valuable and forced me to dig deeper into dronekit code. What I found out is that dronekit uses GLOBAL_POSITION_INT message to receive velocity, which is then divided by 100.0 to get float velocity readings with 2 digits precision.
What I’ve done is I added a dronekit listener on LOCAL_POSITION_NED and now I have full floating point precision readings.
Thank you!
