Hi, I have ubuntu 20.04, ROS Noetic and GAzebo Garden, I have seen that Gazebo garden is not compatible with ros noetic, so I installed ROS Humble from source, is there any way to get the camera images from gazebo garden to opencv? Do I have to use earlier releases of GAzebo?
Also, I wonder that can i control gimbal via dronekit?
You may need to build the repo from source as Gazebo Garden / ROS 2 Humble is not an officially supported combination, although it is the arrangement most commonly used in autopilot development (PX4 and ArduPilot).
By the way, you can also map topics to ROS (1) if you wished to continue using ROS Noetic.
hi @hasann@rhys really fresh user here.
i am trying to simulate a plane with camera in gz garden
i want to see resolution and foV settings
is it possible doing this in garden do i need to use ROS
or should i just switch to classic
it would be so much of help if you can answer
We don’t yet have a plane model with camera in ardupilot_gazebo, but one could be added. Did you want a fixed camera in the plane, or one on a gimbal?
