Hi Paul,
I think those issues are effects of the crash, not the cause of the forward flight motor shutdown which appears to start the chain of events. Both elevons are still perfectly functional.
Hi Paul,
Looking at the changes from v3.8.4 to v3.8.5, I see a couple interesting possibilities. Iām not sure how to tell from the logs if the Safety button deactivated in flight. The second issue has similar keywords to my incident like āfixed wing flightā, āQSTABILIZEā and āzero throttleā. Again this is simply speculation as I gather data.
Fixed an issue where the external safety button can activate in flight on some boards, causing them to crash. A new parameter BRD_SAFETYOPTION is added which controls the behaviour of the safety button. The default is to de-activate the safety button when armed.
Fixed a bug when switching from fixed wing flight to QSTABILIZE in tailsitters which could cause zero throttle for 2 seconds. Thanks to Marco for reporting this bug.
Hi rollys,
Sometimes you gotta break some eggs, right? Iām getting slower to react in my old age so I will need to test fly higher next timeā¦the problem is I canāt see that far!
Cheers!
Greg, Im in the same club, so for fly high I help me with fpv and another trick I ensure that qrtl works well first, that save my wing everytimes
Ok, in this screenshot of your log it shows channel 2 going off just before channel 3. Is ch2 the elevator and ch3 the forward throttle?
Yeah, but the testers in the community are supposed to be the ones that break the eggs so the ones that use the stable version donāt have to.
Yup, I know exactly what you mean. Thatās why I take my son who serves as a second set of eyes with a laptop with QGC telemetry!
Good luck.
Hang in there Greg, You can do it!
Hi Paul,
Yes, thatās correct, CH2 is elevator and CH3 is throttle. However, one of the biggest changes in Plane v3.8 is the change from RCn_* parameters to SERVOn_* parameters. In other words, you are logging my transmitter inputs, not the flight controller outputs to the plane. So channel 2 and 3 are showing my instinctive reactions to slam up elevator and throttle down just before the crash. It had no effect.
Cheers!
Greg,
I will keep plugging away. I hope you are not offended by my blundering around with your log.
Do you have a theory why the servos had such a high activity in the region where the voltage sags?
Is the sag before or after the impact?
Also, it looks like the aileron output behaves unusually as well during the event:
Paul
Paul,
No problem, keep looking. I think where you are getting hung up is on the definition of the āeventā. What you are looking at is my last ditch effort to save the planeā¦long at the initial cause. If you plot CTUN ThrOut with your graphs, you will see the start of the cause when the forward flight motor is shut down which drops the speed and altitude. In my graph above, the CTUN ThrOut (Red) dropped to zero during FBWA mode which appears to have caused the crash.
In your graph, the change to QSTABILIZE mode dropped the Vservo about 0.1 to 0.15 volts. This was likely due to the crash but I canāt tell the exact time frame. As for the ailerons, once in QSTABILIZE mode, they will get yanked around as the plane tries to level itself.
I think your issue stems from your pitch tuning ā you probably need to run an autotune for pitch or there was something wrong with your CG.
Your demanded pitch is near zero and your plane continued to dive. Thatās the problem before you attempted a transition to save the plane. Iāll look into it more later.
Hi Nate,
Thanks for taking a look! I took your graph and added the āeventā parameter called CTUN ThrOut. I consider anything after the āyellowā forward flight (FF) motor dropping out as an effect of the event. In other words, when you are flying just fine in FBWA mode and the FF motor stops, it is like a domino effect. Why did my FF motor stop just as I turned into the wind when I needed it the most? Q_ASSIST_SPEED was set to 0 as recommended for the first flight.
Cheers!
Greg,
Why do you think your battery current spiked during the same second or so that the throttle went low?
Was the throttle off when the aircraft reached the ground?
Paul
Hi Paul,
I donāt have my graph capability at work so I canāt tell the time difference. I suspect the time is longer. The current spike in QSTABILIZE mode is from the quad motors coming on before the crash. My emergency bailout procedure is to change to QSTABILIZE modeā¦although I was too slow this time to save it.
Yeah, so the real mystery is why did the forward throttle go low - i see what you;ve been saying all along now.
Could it be that it thought it had to transition back to quad mode?
Paul
The forward throttle goes low when you go into Qstabilize - because thatās a quadplane mode, and itās expected to hover, not continue in forward flight. Thereās nothing wrong with that.
The forward motor did not stop when you were in FBWA. In fact, the throttle staying at 70% is probably what caused the rapid loss in altitude when your pitch got lower and lower. Switching into Qstabilize unfortunately did not recover. That may be for a number of reasons, but most likely because you had a ton of downward velocity and very little time and altitude for qstabilize to add enough throttle to recover. To get full thrust during the qstabilize, you probably should have given even more than 70% throttle. Who knows though if your battery/power module are rated past 100A.
Nate,
Thanks for the detailed graph. I may have been misreading my initial graphs. I wish we had gotten video of the rapid descending, which happened before I switched to QSTABILIZE mode. I was caught off guard because it was flying quite well. I had pretty much finished the right hand turn, and as it approached the field it went down at about a 45 degree angle. It wasnāt until it was nearing the ground that I reacted to turning the Taranis 6-position knob back to QSTABILIZE mode.
I will try to graph the RC5 (or RC8) input to compare my Taranis knob switch to QSTABILIZE mode with the graphs. Like Paul suggested, maybe it transitioned to QSTABILIZE mode on its own. Even though Q_ASSIST_SPEED was set to 0, I think Q_ASSIST_ANGLE was set to the default 30 degrees, so maybe it caused the quad rotors to kick on in the last turn into the windā¦causing the crash.
I matched RCIN C8 to the CTUN ThrOut and they are in sync. So there was no early change to QSTABILIZE mode and this can also be seen in the green section of my Flight 1 kmz image below. So the real issue was pointed out by Nate in his red circle above which happens on the yellow section before the green on my kmz image. After flying almost a full figure-8 pattern, the wing drove into the ground.
It looks like the aircraft was already descending as the green section has the same angle as the yellow section just prior to the transition to green.
