Moksh
(Moksh Patel)
December 14, 2020, 4:19am
1
Hello everyone I want to make or build Full AIO version board.
Recently some research and after got this
But there is a problem , no baro and magnetometer sensor so it will fix to I2C connection
Question is can I use arducopter on this board like omnibus F4 Vx , Mateksys boards ?
Thank you
That board uses the STM32F411 microcontroller, which only has 512Kb of flash memory.
To run ArduPilot you need a minimum of 1Mb (2Mb preferred) flash memory.
Many flight controllers use the STM32F427 microcontroller, so look for a board that uses this chip.
Moksh
(Moksh Patel)
December 14, 2020, 4:55am
3
What about this ?
And this
And what about beta flight osd ?
Thank you
Those boards should work, but they are not currently supported by ArduPilot.
You will need to write the hwdef (hardware definition) file and test the board yourself. See https://ardupilot.org/dev/docs/porting.html
I’ve not worked with the betaflight OSD.
aamadeuss
(hans bert)
December 14, 2020, 10:11am
5
i like the topic!
what gps / compas / barometer would you recommend?
Moksh
(Moksh Patel)
December 14, 2020, 10:31am
6
Hmm , it’s little bit confusing for me and I can’t afford because every time pushing on Android so I think I cand get it
aamadeuss:
i like the topic!
Thank you
Think about gps , my recommendation is radio link SE100 it’s excellent in my case or at my place (any other suggestions) and it’s free compass with any gps .
Baro is standard pixhawk "MEAS or MS5611 (or any other standard suggestions)
Thank you
