FS-IA6B - ArduPilot does not display any input
https://cdn.discordapp.com/attachments/998764260257693706/1095766867248955413/1ciq5xg.webp
Hey, i connected my fs-ia6b to my fc but it just doesnt detect any input (Setup → RC Calibration)
Could anyone help me?
Use search here for “fs-ia6b”. This is asked frequently. The answer usually is the wrong pins used on the Receiver or iBus/Sbus isn’t confiture on the Transmitter or both.
im 90% sure i did not use the wrong pins:
TX5, 5V and G on the FC; And i attached a picture how i connected the reciever
Doesn’t look right to me but I don’t have one of those radois. If I did I would connect to either PPM or iBus. How many posts did you read after the search?
I read like 10, every one is different :confused:
didnt i connect ibus?
It does look that way. Did you configure iBus on the Transmitter? Try PPM if that doesn’t work.
What FC do you have?
Yes i have. PMM does not work.
grafik
This comes when i finish calibrating (during calibration no input displayed)
Matek F405 Wing
I suppose you have connected to the Sbus pin on the FC? That’s all I got.
From the Matek Website for the F405-Wing Ardupilot page:
F405 ardu
Edit: My bad, i have the F450-WMN
That doesn’t even look like my board…
Your double bad, no such board. However, there is a F405-WMN and the RCINPUT can be found here:
F405-TE/WMN
Yeah, im sorry.
Isnt that excatly where i have connected it (RX5, G, 5V)
RC Input
The RX2 pin, which by default is mapped to a timer input, can be used for all ArduPilot supported receiver protocols
Finally, it worked, tysm!
