I have 4 airframes with working FrSky/yaapu telemetry. All 4 use STM32 UCs. I’m building a new setup around a Beaglebone Blue. Most of the functionality is working, but I’m failing to bring up yaapu telemetry. I built from plane4.0 branch, tag Arduplane-stable).
I’m using a 232 cable from Amazon. The cable is good (tested on F405). I have it plugged into UART01. UART01 and its corresponding port assignment to SERIAL2 (-D /dev/ttyO1) work. If I connect a GPS to UART01 and set SERIAL2_PROTOCOL,5, I get GPS data. When I’m trying to get yaapu telemetry on this port, I set SERIAL2_PROTOCOL to 10.
This is the trace I get. The receiver seems to be polling every 12 milliseconds, but BBBL responds only to id 0x00:
On @tridge’s suggestion, I tried to disable the conditional checking that the serial send completes in 6.5ms (lines 205…208 below). I get a different trace now, but still nothing on Taranis. I traced only the half-duplex line this time. You can see AP respond to more queries. Second screenshot is a zoom-in on one of the queries and responses. I’m attaching a 10-second trace if anyone wants to look at the data in more detail: passthrough.zip (24.4 KB)
