Hi all,
We have Cube Orange autopilot with ADS-B carrier board and arducopter V4.1.5.
We are tryng to configure the FRSKY SPort to read telemetry from cube.
We have configured the serial 1 port (Telem 1) with the following parameter:
SERIAL1_PROTOCOL : 10
SERIAL1_OPTION: 7 OR 15
we have measured with scope the signal between TX and GND pin of Telem 1 port but there isn’t output from the port. If we change the SERIAL1_PROTOCOL on Mavlink (2) we can see signal on the scope.
We also try to connect a 10k resistor between signal (TX pin) and GND but nothing append.
I see on the ardupilot web site that the cube Orange don’t Need an external inverter.
Hi Bruno and thanks for the reply.
Yes, i saw this note and i tried to use it but nothing change for me.
I tried to change the Serial1_Protocol => 3 (FRSKY D) also to check if the port (Serial 1) send out some data and indeed the scope measure something but when i write 10 (FRSKY S-PORT PASSTHROUGH) the scope does not detect anything.
I think that if i set SERIAL1_PROTOCOL => 10 the autopilot must send out something from the port and after that i can change the “serial options” to fix the signal logic (Invert RX, Half Duplex,…),
How do you think ?
Thanks for your time.
Regards
