Frame Type Help
Hi guys. I’m trying to config my first rover with the latest rover firmware. So since all I saw were quads so I went to full parameters and set rover and undefined. Now when I move on in config the radio calibration, for example, why does it still show airplane stick commands? Roll, pitch, yaw etc…? I feel like I can’t move forward because that will surely come back to screw me up later. Someone knows I’m talking about and I can really use the help!
Hello Mike and welcome here in this forum.
I think the first and most traditionell use of Ardupilot and Mission Planner was flying objects. So simply Mission Planner is use wordings coming from this application. But the function is regarding to your loaded firmware. So if you loaded a rover firmware you only get available parameters for this application also in full parameterlist. The wordings are only synonyms.
For the first rover setup see also
https://ardupilot.org/rover/docs/apmrover-setup.html
