Converting a quad which I previously has loaded with iNav.
Got Ardupilot 3.6.11 loaded on Matek405 std board.
Using QGroundControl…
Everything seems to work - radio, gps, etc.
Did you reboot after changing the param? The Betaflight motor order was added specifically for this use case, and has been tested to work. You can of course use X-Class and manually map the channels via http://ardupilot.org/copter/docs/common-rcoutput-mapping.html if it just won’t take the param properly, but that shouldn’t be required.
Ah thanks for clarification. Guess I’ll give 4.0 a try.
Been tinkering with motor order on 3.6 using servo settings but despite the order and rotation being correct using the motor test - it just spins out of control during test flight. :\
Aha! Think I found it - board thinks it’s rotated. Could have sworn I checked that originally but may have reset it when I was changing other params. Lets see if this works
