How can I change the co-ordinate frame of UAV to LOCAL NED in SITL with MAVProxy?
thanks
thanks
Could you be more specific about what you are trying to achieve?
You just need to use LOCAL_POSITION_NED mavlink messages. The UAV already uses NED coordinates internaly
Hi, thanks for the response @Mustafa_Gokce and @amilcarlucas, when I am flying in real world, and give linear velocity in the Y direction, the UAV starts moving straight (the direction in which the UAV’s head is pointing to)
I want the UAV to move ahead (the direction in which the UAV’s head is pointing to) when I give velocity In the +X direction
thanks
That is just not the way it works. The way it works is that forward is +Y and right is +X.
I cannot change it? my planner gives the trajectory in such a manner (+x front, +y right). That’s why I am looking for a solution
Rewrite your planner
NED coordinates are an international standard.
Okay thanks, I’ll look into it
It’s NED as @amilcarlucas said. One reference:
Guided mode commands
Hi, @amilcarlucas this suggests +X is forward or North. I am confused can you please explain me this?
@dkemxr
It is explained in here.
I also suggest you test in SITL.
Hi, thanks for the response, it appears that, when I use mavproxy to send the message it moves north for X but when I use mavros it moves in East for X because of Mavros conversion (NED to ENU) ( I am guessing)
Hi @Mustafa_Gokce, but I still don’t understand why @amilcarlucas said this Frame ardupilot - #5 by amilcarlucas statement referring to NED
Thanks
Ignore my comment. Just test it in SITL
@amilcarlucas this Frame ardupilot - #13 by shubham-shahh is my conclusion in SITL
Thanks
