I had a quad with Cube running arducopter 3.6.11 firmware on it. The initial hover and first few minutes of flight were fine, but about 1 minute into the flight the quad flipped several times and hit the ground in pos_hold mode. I am completely clueless as to what went wrong and request someone to look into it.
PFA for the log file, any help is highly appreciated. #arducopter#development-team
Thank you for your quick response @dkemxr. The motor and ESC were tested after the crash and the values were agreeable with the manufacturer’s datasheet. I’m at a loss as to what else could be wrong. Any suggestions on where else there might have been a mistake?
I had used V3.6.11 on an previous build, everything worked fine in that quad, so I replicated the same build in this quad. I will try using the latest stable version and check. But, could using V3.6.11 be the real reason of the crash? I really want to find an answer for why it crashed to avoid such future mishaps.
I performed the usual bench tests on the motor and ESC and checked current draw, thrust, etc. Results were fine.
Is there any other test I can do to check their working?
