Hi All
I was flying with the SET_POSITION_TARGET_GLOBAL_INT command.
And I want to stop flying.
So, I used DO_PAUSE_CONTINUE. (All parameters are 0)
However, the flight does not stop.
SET_POSITION_TARGET_GLOBAL_INT Code
MAVLink.mavlink_set_position_target_global_int_t setPosition = new MAVLink.mavlink_set_position_target_global_int_t();
setPosition.target_system = (byte)sysid;
setPosition.target_component = (byte)compid;
setPosition.time_boot_ms = 0;
setPosition.lat_int = (int)(x * 10000000L); //lat
setPosition.lon_int = (int)(y * 10000000L); //lon
setPosition.alt = z; //high m
setPosition.vx = 0;
setPosition.vy = 0;
setPosition.vz = 0;
setPosition.afx = 0;
setPosition.afy = 0;
setPosition.afz = 0;
setPosition.yaw = 0;
setPosition.yaw_rate = 0;
setPosition.type_mask = 0b0000111111111000;// (ushort)(MAVLink.POSITION_TARGET_TYPEMASK.X_IGNORE| MAVLink.POSITION_TARGET_TYPEMASK.Y_IGNORE| MAVLink.POSITION_TARGET_TYPEMASK.VX_IGNORE | MAVLink.POSITION_TARGET_TYPEMASK.VY_IGNORE);
setPosition.coordinate_frame = (byte)MAVLink.MAV_FRAME.GLOBAL;
DO_PAUSE_CONTINUE Code
MAVLink.mavlink_command_long_t req = new MAVLink.mavlink_command_long_t();
req.target_system = sysid;
req.target_component = compid;
req.command = (ushort)MAVLink.MAV_CMD.DO_PAUSE_CONTINUE;
req.param1 = 0;
req.param2 = 0;
req.param3 = 0;
req.param4 = 0;
req.param5 = 0;
req.param6 = 0;
req.param7 = 0;
Please tell me how.
Thank you all.
