I am attempting to fly indoors using a Pixhawk 2.1, custom frame, ArduCopter 3.5.5, and Optitrack motion capture system. I can supply a fake gps signal from the mocap system using ROS and the MAVROS fake gps plugin. I am also supplying altitude information via the MAVROS distance_sensor plugin.
I am unable to switch into position hold mode, instead receiving the message “Flight mode change failed” and the error “Flight-Mode Pos Hold refused”. Stablized and Altitude Hold modes work as expected.
Why is position-hold mode refused, even though I have a strong (fake) GPS signal (10 satellites, HDOP=1.0)? How can I find the reason for a rejected flight mode?
Flight Logs
Log 1 (48 KB)
Parameters:
with_mavros_rangefinder.param (15.7 KB)
ROS Configuration:
Launch File:
<!-- Optitrack node gets pose from the mocap system, publishes to /mavros/fake_gps/mocap/pose -->
<node
pkg="mocap_optitrack"
type="mocap_node"
name="mocap_node"
respawn="false"
launch-prefix=""
required="true">
<rosparam file="$(find mocap_optitrack)/config/mocap.yaml" command="load" />
</node>
<!-- Launch a node that publishes a fake rangefinder message based on the above fake GPS signal -->
<node
pkg="mavros_optitrack"
type="fake_ranger.py"
name="fake_ranger"
output="screen"
<!-- Launch mavros, which (in Kinetic) will automatically generate a fake gps signal from /mavros/fake_gps/mocap/pose -->
<!--<arg name="fcu_url" default="/dev/ttyACM0:115200" />-->
<arg name="fcu_url" default="/dev/ttyUSB0:115200" />
<arg name="gcs_url" default="" />
<arg name="tgt_system" default="1" />
<arg name="tgt_component" default="1" />
<arg name="log_output" default="screen" />
<include file="$(find mavros)/launch/node.launch">
<arg name="pluginlists_yaml" value="$(find mavros_optitrack)/launch/pluginlists.yaml" />
<arg name="config_yaml" value="$(find mavros_optitrack)/launch/apm_config.yaml" />
<arg name="fcu_url" value="$(arg fcu_url)" />
<arg name="gcs_url" value="$(arg gcs_url)" />
<arg name="tgt_system" value="$(arg tgt_system)" />
<arg name="tgt_component" value="$(arg tgt_component)" />
<arg name="log_output" value="$(arg log_output)" />
</include>
Fake GPS configuration:
fake_gps:
use_mocap: true # ~mocap/pose
mocap_transform: false # ~mocap/tf instead of pose
use_vision: false # ~vision (pose)
# origin (default: Zürich)
geo_origin:
lat: 41.6994 # latitude [degrees]
lon: -86.2372 # longitude [degrees]
alt: 408.0 # altitude (height over the WGS-84 ellipsoid) [meters]
eph: 1.0
epv: 1.0
satellites_visible: 10 # virtual number of visible satellites
fix_type: 5 # type of GPS fix (default: 3D)
tf:
listen: false
send: false # send TF?
frame_id: "world" # TF frame_id
child_frame_id: "fix" # TF child_frame_id
rate_limit: 10.0 # TF rate
gps_rate: 5.0 # GPS data publishing rate
