Hi, I am using a Herelink paired with a Pixhawk cube which runs a serial connection (telem2) to a onboard computer + camera. The onboard computer calculates and sends (velocity body) commands to the flight controller (using dronekit-python) based on the images it sees.
I am finding that when I try to change flight mode on my controller, it gets completely ignored (most of the time) by the drone. This only happens while my onboard computer is sending commands.
I am guessing it is because my commands sent via serial are blocking the serial line? ie spamming the flight controller so it can’t receive anything else.
Is there a reasonable/safe rate I can send commands to the flight controller without flight mode changes being ignored? I am currently doing it about 20 frames a second (my frame rate).
I posted here because I figured this is to do with the Arducopter stack and not necessarily the Pixhawk.
No I am not constantly sending mode changes from within my code. Using the stripped down version of my code (below), ie just sending velocity body commands with no other functionality, the problem remains.
def send_commands(x,y,z):
msg = self.vehicle.message_factory.set_position_target_local_ned_encode(
0, # time_boot_ms (not used)
0, 0, # target system, target component
mavutil.mavlink.MAV_FRAME_BODY_OFFSET_NED,
# frame ... MAV_FRAME_LOCAL_NED usually used but its local to home
0b0000111111000111, # type_mask (only speeds enabled)
0, 0, 0, # x, y, z positions (not used)
self.command_x, self.command_y, self.command_z, # x, y, z velocity in m/s
0, 0, 0, # x, y, z acceleration (not supported yet, ignored in GCS_Mavlink)
0, 0) # yaw, yaw_rate (not supported yet, ignored in GCS_Mavlink)
self.vehicle.send_mavlink(msg)
while True:
# Runs at around 20 iterations / second
image = read_image()
x, y, z = calc_commands(image)
My question is about a safe rate I can send commands to the flight controller at without potentially squashing other commands from rc.
I was using a herelink controller, which apparently also uses dronekit/pymavlink/something to talk to the flight controller in some instances. This means that it connects using the same system source as what my code tries to use (the default is 255), so my connection and the herelink connection were arguing/fighting with each other over who gets to talk to the flight controller. Changed source_system=1 when I connect and it worked out.
What parameter did you change and to what? Also was it as paremeter within mission planner or in your code? Im having the same mode switching issue but the cause is I updated a pixhawk 1 from px4 to ardupilot and now my modes will not switch even though the pwm’s and switches are set up correctly.
I changed it within my code, dronekit makes it very easy to change the source id my companion computer uses. My issue was that both my companion computer and the Herelink were fighting over the same id, your issue seems slightly different. As a place to start I think that you can change the id that the herelink uses in its settings? I can’t remember where but it is defaulted to 255 fairly sure.
If anyone sees this and still has questions, I was able to find a work around when trying to connect an Nvidia Jetson to a pixhawk over serial. I could read the packets but my commands were ignored, so I configured the aux outputs as GPIO and set them as RC inputs so I could read the mavlink packets and change the mode of my drone over pwm.
