Hi guys, I have a Pixhawk (not cube version) that I run in a plane that has a pretty old firmware in it because the USB port is broke (connector broke off) so I can’t load new firmware onto it. I am wondering if I can upgrade the firmware through the SD card? I have searched around and found where people say you can put the Pixhawk into bootloader with the switch but how do I get the Pixhawk to read a firmware upgrade from the SD card? If anybody has a workflow that would be appreciated.
Yes, that sounds great and thank you for the link. Will that USB connection work the same as the micro USB that broke off when I do a firmware upgrade or is there anything special I have to change?
