Could somebody point me where I can find the source code for the RfDesign x series radios? They contains a new ARM based EZR32 wireless uController and RfDesign states that the firmware is ported from SiK, therefore it must be open source as well. I’m planning to add some features (SBUS, Auxiliary data channels) but was not able to find the source code…
No it is not there, that is a very old version, contains source code up to version 1.9 the 900x uses version 2.6 and a completely different processor (ARM-M3 EFM32 from Silabs).
I guess they are not forced to do anything: BSD 2-clause
The 900x (868x) and their TXMODs look like a very promising approach to eliminate all these closed source black boxes related with RC radio links. Unfortunately, the situations seems to be not much better here. Too bad…
Today I found The TXMOD has proper sbus which is good as I tested it.
Since I got the TXMOD in last June, I tested it with 3.07 version.
PPM was good but Sbus was bad. Moreover, TXMOD firmware which is listed in support page had bugs which result in malfunction.
I requested it fixed with hardware change. And today, they completed to upgrade it with version 3.09 for x900x and I got the New TXMOD already.
The result of test was good.
Now I can control the UAV with sbus, though it is 20km apart from Taranis x9D RC Transmitter.
By the way, is there any difference between RC-override through mavlink and sbus control in the perspective of delay?
Looks like they updated user manual for the 900x which has instructions on how to enable sbus on firmware 3.09 looks like it is using same pin (15) as the ppm passthrough. Also apparently you can feed the tx ppm and set the rx to spit out sbus.
The firmware for the 900x series radios isn’t released as open source unfortunately.
We found that our products were cloned quite quickly for the RFD900+ and 900u series modems and made the decision to not open the 900x and later modems.
If there are any new features required, or something that would be really cool, we would most definitely welcome feedback, comments and requests!. We have worked with some OEMs on collaborative feature development, so, anything is also possible
SBUS has been recently added, and have put a lot of work into the multipoint firmware on the 900x and 900ux series modems, with around 30 modems synchronised in a network concurrently.
Hello, Yes, there will also be an RFD868ux … Pilot runs are being assembled at the factory at the moment!. Planning to have 900ux and 868ux available for purchase in about 3-4 weeks.
The product description on the RFDesign website says the ux model is “Fully compatible with RFD900x modems.” So it looks like they should be able to communicate.
hi everybody. I have a very basic question about those modules, which i could not find answer reading the manual (TXMOD+RFD868ux, peer-to-peer).
How the binding works? I hope there’s a quick and convenient “push one button on each side” a-la frsky, something which don’t require to connect module with a PC. I couldn’t find such a procedure in the manual, though. I see the TXMOD has a button, is it for that?
Otherwise, i used old sik radios like 3DR and they don’t have any pairing procedure, just a silly and useless “net ID” selection which is weak from a security perspective and unconvenient since you need to connect module with a laptop running mission planner, etc…
Why do that. Frsky system uses the same ID system.
If two frsky system want to work paralel then each of them have to have a different id.
The pairing is just a foolproof mode to set the same ID on the RX.
eos, ID on frsky system is a long enough, “unknown” number, which is randomly choosen with a simple procedure without PC connection. Net ID into SiK radio is a silly 0 to 100 or something number which is easily crackable
