Filter tool help
I cant load my files to the web filter tool i keep getting this wrror
Please upload the log somewhere and send me a link so I can reproduce the problem.
https://drive.google.com/file/d/1TfjJjipm6qkSgeKiNu2iH3K-Bj3GWj4d/view?usp=drivesdk
Can you also look at it and tell me whst i should do. Im trying to learn but its over my head :slight_smile:
Heewing T2 vtol
Here is a working log. Im trying to use throttle based notch. My esc wont all read so bluejay wont flash. Im going through the online tool but i dont understand what is acceptable? My quess was rpm notch around 125hz freq, 62 BW, 40 ATT with .3 hntch ref
Gyro 60hz
Or am i way off base
That log has no filter set.
Try:
ARMING_CHECKS,1
INS_HNTCH_ENABLE,1 # You'll need to reset after this
INS_HNTCH_MODE,1
INS_HNTCH_FREQ,141
INS_HNTCH_BW,70
INS_HNTCH_ATT,40
INS_HNTCH_REF,0.4
INS_HNTCH_FM_RAT,1
INS_HNTCH_HMNCS,1
INS_HNTCH_OPTS,0
LOG_BITMASK, 65534 # There's a lot of tuning information missing from the logs.  This will help and still get filters set.
You should also look over the tuning process instructions because much of what’s set on this plane are conflicting.
https://ardupilot.org/plane/docs/quadplane-vtol-tuning-process.html#step-3-pid-controller-initial-setup
What is conflicting? Ill set those params and retest in 12 hour’s. What should the gyro_filter hz be? Its 10 inch props. 40hz?
And thank you. Im trying to figure this tunning part out. I just want to be able to take off without hot motors. Im not going to use vtol for anything but take off and land.
Im using heewings parameters which work but not very well. It can take off and land in vtol. Transitioning works but the motors get hot after 2 minutes in a hover. They also shake a little sometimes while in a hover.
I am getting similar issue
Significantly better with your paramters. I did another log
https://drive.google.com/file/d/1VvmtFboRPIWwCmZYV0dEq92zwlpPzYPC/view?usp=drivesdk
I managed to flash bluejay for bidirectional dshot. If i enable the channels my Motors wont spin and it showns pwm1-10 instead of pwm 1_6 DSHOT600 7-9 pwm 10. Without channel 7,8,9 bidirectional bit mask checked everything works. Its a heewing fx-405 v2 FC. My motor channels are 7, 8, 9
Thats why im using throttle based notch filter
Changed motor timing from medium high to medium 15° that cooled down the motors a lot. I did a short hover but i was in a small space. I had to move sticks.
I added a notch and im probably doing it wrong. It does hover better.
I hope someone can help me get this right
https://drive.google.com/file/d/1Wh8o4f89j1KXFWc5miWqFihkQB3lLqHS/view?usp=drivesdk
There is nothing really to work on for the Notch Filter in this log.
Set these and make another longer flight.
LOG_BITMASK, 4206526
INS_LOG_BAT_MASK, 4
Ok ill dp thar right now. Ill have the log in 10 minutes
https://drive.google.com/file/d/1WimtnaJ8Z1ZqTVjbz80O9od8GHQFW7ga/view?usp=drivesdk
I know my current settings are totally off.
Still nothing to see. Disable the Notch Filter. What prop size is on this VTOL, maybe the Gyro filter is set too low.
One concern is the thrust/weight. Looks underpowered/overweight with one motor at max, during Yaw it looks like, which is not good.
Ok ill try again. Its a 10 inch prop. So ill disable the notch and try agin. Be back shorty. Thanks for looking
For 10" props according to Tuning Process Instructions — Plane documentation
INS_GYRO_FILTER, 40
Q_A_ACCEL_P_MAX, 50000
Q_A_ACCEL_R_MAX, 50000
Q_A_ACCEL_Y_MAX, 6750
Q_A_RAT_PIT_FLTD, 20
Q_A_RAT_PIT_FLTT, 20
Q_A_RAT_RLL_FLTD, 20
Q_A_RAT_RLL_FLTT, 20
Q_A_RAT_YAW_FLTE, 0 # for vectored yaw
Q_A_RAT_YAW_FLTT: 20
Set the parameters @Allister has suggested, then do another flight.
Ok ill have the logs in a hour. Do i just hover? Im only going to take off and land in vtol. Not fly around.
Ok the documentation say 110000 but ill use your 50000
Also my stock heewing params for Q_A_rat_yaw_fltd 40 Q_A_RAT_rll_fLTD 40. Should i leave those as is
Sorry, my bad. The max setting should be 110000 for 10" props.
I’d use the filter settings as per the wiki.
