i have a reading of a distance sensor, and i would like to apply a command for a servo>
Example: if the the distance less than 10 cm, the servo turns once
yes you should find everything you need in the set servo example and the rangefinder example.
Can i do it just using the parameter list in Mission planner ?
there is no parameter for turning a servo when i rangefinder distance is below a set value.
