Hello all,
I am trying to upload fence polygon using mavproxy.py
my experiment setup is the following:
- Open SITL with the rover, fences enabled, Object avoidance is Dijkstra and avoid enable = 0
- run mavproxy.py
- connect with TCP 127.0.0.1:5762
- write "fence load “\path\to\fence.poly”
after step 4, I’m always getting this issue:
MANUAL> fence load "D:\fence.poly"
Loaded 6 geo-fence points from "D:\fence.poly"
Failed to send fence point 5
MANUAL>
I get the “.poly” file by drawing a polygon and clicking save polygon button. when i check the fence.poly the input is the following:
#saved by Mission Planner 1.3.76
35.6351466868017 34.5220202207565
35.635403920251 34.5253139734268
35.634490514543 34.5254909992218
35.6335771088351 34.5256680250168
35.6332021495376 34.5220953226089
35.6343488218537 34.5220148563385
to debug what is going on, i played a little bit and checked the source code. i printed what is happening and what causes this issue.
Loaded 7 geo-fence points from "D:\fence.poly"
p.lat: 35.6351466868017
p2.lat: 35.63540267944336
p.lng: 34.5220202207565
p2.lng: 34.52531433105469
Failed to send fence point 6
I tried erasing the last point. because the last point is basically the duplicate of the first point. it didn’t work either.
Any suggestions on that?
Thanks
