could you help me please…
when my quadcopter hover and then i set my drone to mode loiter , auto etc, my drone landed immediately("Flight mode change failed” error when switching to all mode except
mode stabilize) , i used pixhawk 2.4.8, and in the mission planner EKF was red ,but gps is
3D fix . could you help me to fix this problem pleasee…cause i stuck in this problem…
3D fix doesn’t guarantee a good position estimate. Post a link to your .bin log file.
https://drive.google.com/file/d/11FmaHt8x8ljoQO1x0vFRK2ibVHjstEvw/view?usp=sharing
this is the log , please help me
I can’t check the logs right now so answer, how many satellites were locked and what was the gps hdop? Is the compass calibrated?
11 satelit and hdop mean 0,68
i had calibrate compass
Looks like you are switching between Loiter and Stabilize to me.
You are flying this on default parameters? Didn’t read the Initial Tuning Guide?
https://ardupilot.org/copter/docs/tuning-process-instructions.html
There is a tuning Plug-in in Mission Planner also. After connecting hit Alt>A
I think, i,ve set the params was default. this problem happened after my quadcopter had loss from the signal remote in altitude 42 m , and then my quadcopter went to loiter mode , after 60 s it been auto land.
please help me to finish this problem
You absolutely need to set up failsafe following this guide: https://ardupilot.org/copter/docs/radio-failsafe.html
The log you posted doesn’t show an altitude above a few meters.
before that happened it was loss in 42 m , but i’had reset the pixhhawk and the log was reset too cause i thing it’ll good again
this is the vidio of the problem in my quadcopter : https://drive.google.com/file/d/19YGanH_2RNteWS7pkW1ATR-XTvc2BgIv/view?usp=sharing
