Hello how do I set a fail safe so that if I lose signal/video during a mission the drone will continue the mission and then RTL .
I keep getting this error
In the picture the error is because I changed the value to 2 so with that being said do I need to keep it like that then follow the steps you sent or do I delete that value and just go with the setup the way u sent
Those errors are about GCS failsafe, nothing to do with throttle/signal. Disable that and set the throttle/signal FS actions with the Options parameter.
Thank you about to do that now
The FS_THR_VALUE parameter is covered on the Wiki Page I sent the link for. It needs to be set lower than the throttle value when it loses signal.
Leave the Timeout parameters at default.
