Wanted to test the 3.6RC6 firmware on the Cube. After writing firmware, the extended tuning parameters are set to a non editable zero value on:
- Throttle Accel
- Throttle Rate
- Altitude Hold
- Position XY
- Velocity XY.
Is this meant to be like this?
please have a look at release notes
8) parameter and log message name changes:
a) ACCEL_Z_ renamed to PSC_ACCZ_
b) ACC_ parameters renamed to PSC_ACC
c) POS_ parameters renamed to PSC_POS
d) VEL_ parameters renamed to PSC_VEL
e) FS_BATT_ renamed to BATT_FS_
f) BATT_AMP_PERVOLT renamed to BATT_AMP_PERVLT
g) PILOT_VELZ_MAX to PILOT_SPEED_UP (and PILOT_SPEED_DN)
h) RC_FEEL_RP replaced with ATC_INPUT_TC (functionality is same, scaling is different)
i) WPNAV_LOIT_ params renamed to LOIT_
j) NTUN dataflash message renamed to PSC
MP don’t know these renamed or new Parameters yet - so if you want to change these you have to go to Full Parameter List or Tree
Greetings
QGC is updated., Try it.
I’ve created this issue so hopefully @meee1 (or someone else) can update the MP’s extended tuning screen.
I’ve tried to fly with the 3.6 firmware, just for a few seconds and crashed the octocopter. It was absolutely fine on the previous version.
Cannot figure out if this is due to the firmware upgrade or not.
Log File
