ExpressLRS backpack Mavlink connection troubleshooting
Greetings
I am using jumper T14 and pixhawk 2.4.8 flight controller.
I followed the wiki and everything is setup accordingly.
I have the basic understanding of expressLRS now
Rx TX are flashed and bind successfully
backpack is flashed successfully
Lua script installed
The problem:
If I use the external LRS TX ( happymodel 900 ).
In the lua script when I go to the backpack menu the on and off switch is not visible and I cannot see any WiFi hotspot on my laptop to connect to it even though I set telemetry to WiFi
Other devices ( RX ) is set to mavlink and TX link mode is set to mavlink.
If I use the internal LRS
From the lua script menu I can’t see link mode option to change it from normal to mavlink، However in the backpack menu I can see the on and off switch but not the telemetry option to change to mavlink.
Any idea what’s going on here ?
I am trying to connect to mission planner through the LRS backpack.
In mission planner I changed some parameters according to the wiki
