Hey everyone, this is my first time with ardupilot. I’m trying to set arduplane up on an esp32 dev board.
I have folllowed the build steps and everything is installed (mavproxy, gcc-arm, cygwin and all its packages along with the whole devel package). I have cloned the ardupilot repo from git and installed extra python packages.
I have referred to these webpages:
when i run waf configure, it says:
$ waf configure
-bash: waf: command not found
when i run python waf configure, it gives this output:
$ python waf configure
Setting top to : /home/Paarth/ardupilot
Setting out to : /home/Paarth/ardupilot/build
Autoconfiguration : enabled
Checking for program 'python' : /usr/bin/python
Checking for python version >= 3.6.9 : 3.9.16
Setting board to : sitl
Using toolchain : native
Checking for 'g++' (C++ compiler) : /usr/bin/g++
Checking for 'gcc' (C compiler) : /usr/bin/gcc
Checking for c flags '-MMD' : yes
Checking for cxx flags '-MMD' : yes
CXX Compiler : g++ 11.4.0
Checking for need to link with librt : not necessary
Checking for feenableexcept : no
Enabling -Werror : yes
Enabled OpenDroneID : no
Enabled firmware ID checking : no
GPS Debug Logging : no
Enabled custom controller : yes
Checking for HAVE_CMATH_ISFINITE : yes
Checking for HAVE_CMATH_ISINF : yes
Checking for HAVE_CMATH_ISNAN : yes
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : yes
Checking for header endian.h : yes
Checking for header byteswap.h : yes
Checking for HAVE_MEMRCHR : no
Configured VSCode Intellisense: : no
DC_DSDL compiler : /home/Paarth/ardupilot/modules/DroneCAN/dronecan_dsdlc/dronecan_dsdlc.py
Source is git repository : yes
Update submodules : yes
Checking for program 'git' : /usr/bin/git
Checking for program 'size' : /usr/bin/size
Benchmarks : disabled
Unit tests : enabled
Scripting : maybe
Scripting runtime checks : enabled
Debug build : disabled
Coverage build : disabled
Force 32-bit build : disabled
Checking for program 'rsync' : /usr/bin/rsync
'configure' finished successfully (14.798s)
but when i run python waf configure --board esp32diy --debug, it says:
Setting board to : esp32diy
Using toolchain : xtensa-esp32-elf
Checking for 'g++' (C++ compiler) : not found
could not configure a C++ compiler!
(complete log in /home/Paarth/ardupilot/build/config.log)
i tried installing cygwin and gcc compiler again but I am not able to fix the issue…
i feel i am missing something but not able to figure it out…
i tried python waf plane and it says:
$ python waf plane
Waf: Entering directory `/home/Paarth/ardupilot/build/sitl'
Embedding file locations.txt:Tools/autotest/locations.txt
Embedding file models/Callisto.json:Tools/autotest/models/Callisto.json
Embedding file models/plane-3d.parm:Tools/autotest/models/plane-3d.parm
Embedding file models/plane.parm:Tools/autotest/models/plane.parm
Embedding file models/xplane_heli.json:Tools/autotest/models/xplane_heli.json
Embedding file models/xplane_plane.json:Tools/autotest/models/xplane_plane.json
you need to install pexpect with 'python -m pip install pexpect'
