Hi Ya’all. Just completed a new build with a known good Pixhawk FC and working 4 in 1 ESC. When I try to arm the quadcopter, I get an ESC tone and a screen message that says it is arming – then nothing. The motors don’t start. The log says it is running and I need to disarm the system to to continue. Is there a config item I’m overlooking?
What did it do when you ran Motor Test in Mission Planner?
Nothing. The motors don’t activate
It’s something fundamental then because Motor Test doesn’t require arming. Post the parameter file and check the signal wiring.
