I’m currently trying to setup Dshot 150 on a quad with a Tekko32 on a Cube with 4.0.3. I’ve followed the instructions on https://ardupilot.org/copter/docs/common-blheli32-passthru.html. When I select “connect” in BLHeli32 Suite I get the following pop up warning.
Performed the procedures. Associated motor does not spin. After each attempt the ESC chimes would initiate. Nothing about dshot in the messages. 2020-06-26 DSHOT Tuning 2.param (17.2 KB)
Look like the tests passed for each ESC, so the problem is between AP and BlheliSuite. Try downloading the latest version, you should connect to the same serial port with the same baud rate as you do Mission Planner (having disconnected MP first)
I’m consistently able to get Passthrough to work on BLHeli32. My newest problem is getting ESC telemetry to log. Here are a couple of failures that I’m seeing as well.
Anytime I send an SERVO_BLH_TEST command, Mission Planner displays “Initialising APM” under the Messages tab. I simultaneously get the ESC tones on boot. So I’m assuming my pixhawk 2 did indeed re-initialize. However, I also get a “ESC: Test PASSED” after.
When I try to do a motor test, in BLHeli32 Suite, I’m only able to send 1010 pwm’s. The AP sends the re-init tones again, and I have to re-check the “I understand…” portion in BLHeli to perform another motor test.
I’ve been having to do a lot of repairs due to motors failing in flight. The ESC telemetry would be a huge help trying to find the root cause of my motor failures.
Maybe you could share what your motor failures are, when does it happen and quad specs (motor/battery/props/AUW/etc) and a picture of the failed motor(s).
I’ve seen multiple failure types. Scorching on the ESC’s, Motors binding, and others. I don’t have pictures unfortunately. My main objective is to get ESC telemetry logged though.
The reason i asked my questions was to see if its a mis-match of esc/motor/prop/battery/AUW or simply cheap hardware. I mainly fly betaflight LOS high preformance quads and this type of flying is murder on esc/motors, I am hitting 120A/2100W on a 230mm mtm quad. I have found though testing what has failed and now works well (+20,000 flights w/o failure). There is 10 ways to skin a cat (btw, I like kitties, I have two).
What motors/props/battery/AUW is your quad?
Do the motors get warm or hot?
Do they sound smooth (oscillation and D-term spikes heat motors)?
Hi folk
I have replaced blheli s with TEKKO blheli32 on my Hexa. Since I am using Li-ion battery I want to change some parameters in Tekkon and also reverse the motor direction of some of the motors. After several attempts I was able to connect to Blhelisuite. I managed to change the parameters and also the direction of the motors. Everything seems to work and the motors rotate and I can arm the machine.
Why works the connection a bit random?
The FC is Pixhawk 6C, Arducopter 4.4.3, Blhelisuite 32.9.0.6.
