Not all ESCs transmit data to the flight controller.
When arming, all 4 motors are spinning, but the quad is not adequate and I noticed that these RPM value do not come to the flight controller.
ESC: 4 in 1 BLHeli_S with firmware from Bluejay
FC: MatekH743
Firmware: Ardupilot Copter MatekH743-bdshot 4.2.3
Through testing the motors in the Mission Planner I made sure that the motors were spinning in the correct direction and positioned correctly.
Why are the rpm readings not displayed, should they be?
bdshot is not supported on anything other than PWM1-4 on this board. On some of the newer boards I have been providing 8 bdshot channels, but this is quite expensive in DMA channels and the Matek board is using a lot. I will see if it can be updated.
Thank you! Thanks for the quick response. Please post here after watching. I’m really looking forward to! I’ve been trying to get the copter working for a few days.
Understand. It would be nice if you keep up to date with what is happening on this topic.
Andy, I have another question, ESC telemetry is not used by the controller in any way during the flight, but only as information that can be displayed on the OSD or ground station, or am I wrong? @andyp1per
