I made a hexacopter drone using Pixhawk 2.4.8. when i am trying to do ESC calibration it not working. I followed all the steps properly. first make throttle fully up position and then connect the battery and after remove the battery. and then press safety switch and throttle down. but after that the motor will not starting rotating…
Trying to calibrate the ESCs without having the RC connected and configured can under some situations cause issues.
Following a proven and tested configuration sequence is the only way to make sure that you do not fall into a Rabbit hole. But that is just my opinion.
