When calibrating new esc’s with Dshot125 selected once i hit the arm switch i get power to the motors kida scary. changing back to normal can also power up the motors. once power cycled it seems ok.
I running 3.6-10-rc2
I’d wager you have the ESCs connected to the “normal” motor outputs. They should be connected to the AUX ports instead. http://ardupilot.org/copter/docs/common-dshot.html .
Why are you using rc2? 3.6.10 has been released…
HI, I been slightly backlog at work not got a chance to update but will soon.
Ah good thinking…
Oneshot125 or Dshot150 and more.
If Oneshot125, normal motor outputs, if Dshot, follow the wiki.
Set MOT_PWM_MIN at 1000 and MOT_PWM_MAX at 2000 and calibrate your ESC with theses parameters.
