I am making a new setup with a new plane. I reflashed my Matek H743 - it happens the same thing with both arduplane 4.0.8 and 4.1. I configured that via MissionPlanner (ranges, calibrations and in parameters only disabled arming required)
Once I connect battery up, motor makes intro sound but only a single one. Receiver and transmitter connects - however it takes like 5-6 seconds once the servos start to respond. There is no any further sound of a motor and it does not react on throttle stick movement - only servos work. No USB connection at this point.
When I disconnect battery and as first power up via USB, open up a Mission planner, plug in the battery then motor play intro sound followed by few tones showing it is ready to work - and it does work.
When I bypass entire FB it works right away, it arms and spins.
I checked it on the separate set of a motor and esc and the very same thing happens.
In summary it seems, like only after connection to PC motor works. Any ideas why?
Only esc changed and nothing else in FC setup?
Second set of motor and esc that I’ve used to check if the problem exists, was working fine some time ago with same FC on another plane.
I had some issues here and a simple swap of the ESC solved it for me. I heard in discussion, that every ESC should work with every FC, but obviously not with me. And maybe not with you also.
Those were two 20A HK ESCs and three CC3D revo minis. Just old stuff.
So in my eyes not worth doing any further trouble shooting.
Following sequence:
SD card inserted into FC
FC not connected into the PC
I power it up (with LiPo) motor will make just a welcome sound (no seeking beeps for binding/arming) only. I can arm/disarm the the motor but it seems not to be connected.
I need to re-plug the ESC cable on CH3 on the FC board. Then it binds, I can arm and run the motor.
Following sequence:
FC is connected into the PC
I plug the battery up (LiPo). Motor binds. I can arm and run the motor.
Following sequence:
SD card is not inserted into FC
FC may or may not be connected into the PC - work the same both ways
Seems like only unplugged SD card or PC connection allowes my motor to bind right away without re-connection of the ESC on the board. Tested with another ESC - same issue.
Can anybody explain what is happening over here?
I really cannot understand the logic.
P.S. I can record a short video if that explains issue better.
@Maciek_S did you solve this? I have the same issue. Seems like the h743 is too slow to boot up and the esc will not arm if the time between battery on and pwm signal ok is too long. I am guessing the sd card is slowing down the boot, thus why it works without it.
