Ran into “Set param error. Please ensure your verson is AC3.3+” when trying to calibrate some BLHELI32 ESC’s in Arduplane 4.5.0dev. Searching the forum I ran across several discussion about updating arduplane firmware and mission planner, but I am running what appears to be latest. What could be causing this?
This is on a Matek F405-VTOL, ESCs are Lumenier BLHELI_32 51A from Getfpv.
I just realized it advertises DShot1200 compatible, and I’ve set Ardupilot to DSHOT600. But it also mentions “auto detection” in spec, so it should work? The motors aren’t even spinning up.
I am actually troubleshooting why ESCs aren’t responding. I was hoping to see some reaction through calibration menu even though it’s not needed for these digital protocol. I enabled passthrough and BLHELI32 configurator can’t even connect! I need to double check my wiring and setting to see what could be causing this…
