When compiling the firmware for Pixhawk6X-ODID using ‘./waf copter,’ I encountered the following error and don’t know how to resolve it.
dronecangen returned l error code/home/acnpro/ardupilot/build/Pixhawk6X-0DIDWaf: Leaving directoryBuild failed-> task in'dronecan' failed(exit status 1):{task 139912919357072: dronecangen .github,ardupilot,com,cuav,dronecan,mppt,tests,uavcan -> ?(run with -v to display more information
dronecangen returnedl error codeC/home/acnpro/ardupilot/build/Pixhawk6X-0DCalling ant_glob on build foldersID) is dangerous: add quiet=Trueremove=FalseCalling ant_glob on build folders (/home/acnpro/ardupilot/build/pixhawk6X-0DID) is dangerous: add quiet=Trueremove=FalseCalling ant_glob on build folders (/home/acnpro/ardupilot/build/Pixhawk6X-0DID) is dangerous: add quiet=True remove=FalseCalling ant_glob on build folders (/home/acnpro/ardupilot/build/Pixhawk6X-0DID) is dangerous: add quiet=True remove=FalseCalling ant_glob on build folders (/home/acnpro/ardupilot/build/Pixhawk6X-0DID) is dangerous: add quiet=Trueremove=FalseCalling ant_glob on build folders (/home/acnpro/ardupilot/build/pixhawk6X-0DID) is dangerous: add quiet=True remove=FalseWaf: Leaving directory/home/acnpro/ardupilot/build/pixhawk6X-ODID
Build failed-> task in'dronecan' failed (exit status 1):{task 139917679385888: dronecangen .github,ardupilot,com,cuav,dronecan,mppt,tests,uavcan -> 3
dronecangen .github,ardupilot,com,cuav,dronectask 139917679385888:an,mppt,tests,uavcan ->
