@Allister@tridge I have designed a twin vector thrust canard plane and planning to Q_TAILSIT_ENABLE = 2. See the video attached. Plane flies both in manual and FBWA mode with no issue (Ignore sarcasm in the beginning).
Since there is no frame configuration matching my design, I think Q_FRAME_CLASS =10 would be ok??
Is airspeed sensor must have for tailsitter? At the moment, I don’t have airspeed sensor on the plane but I can add one on.
Then set SERVOX_FUNCTION to 75 and 76 (TiltMotorFrontLeft and TiltMotorFrontRight) for the outputs controlling the canard/motor tilt servos, and set SERVOX_FUNCTION to 73 and 74 (ThrottleLeft and ThrottleRight) for the outputs controlling the motor ESCs.
It is a belly sitter but does not have independent vector thrust control. Both motors are coupled with single servo. If I can simply achieve STOL landing that would be remarkable, and only person @iampete could answer this question. I watched his presentation on youtube and there are several other parameters that could accomplish that (I think ).
In that case I think you’d set SERVOX_FUNCTION to 41 for the tilt servo, and set SERVOX_FUNCTION to 73 and 74 (ThrottleLeft and ThrottleRight) for the outputs controlling the motor ESCs.
