I had connected to my PC via the telemetry radio, and I had just enabled GeoFence. I set the altitude to 30m, and then I got an error popup indicating that it had failed to set the altitude limit.
This message kept popping up over and over again, and I couldn’t close any of them. My taskbar filled with them. I had to close mission planner via the task manager. Now the telemetry radio will not connect.
USB still works. And my settings are still there.
coolguy1.param (21.4 KB)
None of the lights on the telemetry radio on the quad are lighting up. The ground unit is still fine. Do I have a hardware issue?
EDIT: +5V wire seems not to have connectivity. I think I’ve found the problem
EDIT2: Yep. I resoldered the connection and now it’s working again.
