cyberpilot360,
im flying 4.03 with pixhawk1, pixhawk2 (Black Cube) and pixhawk4 (holybro)
On all Hardware the same symptoms:
not permanent; mostly after a while when they stand still on the ground; reboot Ctrl+F helps; when the message is their arming is not possible. etc…
It started with software 4.0
But if it consistently, their must be another problem as well. Calibrate all the sensors again would be my next step.
@rmackay9 randy, you are so quite in this issue, can we do something to help?
Funny, today I flow a new build kopter, cube black, firmware 4.0.3.
This time I start at zero. A new controller, new calibration, writing all the params new in manual (and not from an old saved file) etc.
First Time for long that I didn’t here any “yaw inconsistenc at xxx deg”
Maybe that is the key… To reset everything and start from the beginning
Thanks for the report on the “DCM Yaw inconsistent” pre-arm message. I think this was added to Copter-4.0 as an additional safety check of the attitude before takeoff but I’ll bring it up at our weekly dev call tomorrow and consider removing it. Copter never falls back to DCM so it might be OK to remove it especially if we are finding there are more false positives rather than real issues.
By the way “DCM” stands for “Direct Cosign Matrix” and it is attitude estimation system that pre-dates the EKF (mentioned on the wiki here )
I had this for the first time today - Pixhawk with ArduCopter V4.0.3 the inconsistency was between 20 and 28 degrees, but only when it was on the ground.
We have this problem with 2 drones, both cube black and RM3100 compass. It comes 1-2 minutes after connecting the battery. Only solution so far, we let the cube warm up and restart.
It does not happen with another drone, cube orange and here2.
The question is, where does this problem come from?
I have some problems on a drone with RM3100 too. The more i use and try to fix it the more i think there may be something wrong with the driver. Being relatively new it could be some little bugs that will be solved in next releases.
I solved by changing the CAN cable to STANDARD(i2C), and using the i2c external compass. I had many problems using the CAN system, many times the board (Pixhawk 2.1 cube black) does not recognize a compass.
Little update from us, we used the Drotek RM3100 and this GPS Module with integrated Compass:
We connected the Compass from the GPS module, calibrated it, same problem. Because the black cube had some gyro drift on the IMU2, we had to exchanged it with an orange one.
Did a new calibration with the lis3mdl, the problem did not occur so far and we will test it tomorrow with the RM3100 again.
Anyone come up with any work around for this issue? I am also getting this “EKF2 Yaw Inconsistent by XX degrees” message after flight that is more than about 2min long. Consistently about 15sec after I land I get this message and cannot arm. Rebooting makes the issue go away (until I land again) or I can wait about 3min and the message will go away.
Ive tried recalibrating many times and disabling compasses with no success. (V4.0.3)
