All
Here is analysis window from last flight.
Is fine at startup, all alerts and fail safes clear. When a few meters off the ground it starts toilet bowl yaw and goes through some EKF lane changes. I seems to settle on a lane and flight can resume as normal. Yaw event is SCARY!
I have posted the Auto Analysis below and the logs for the last couple flights are in:
Please help.
Log File C:\Users\kowpa\Documents\Mission Planner\logs\HEXAROTOR\1\2023-09-07 10-01-00.log
Size (kb) 21500.7333984375
No of lines 240562
Duration 0:22:52
Vehicletype ArduCopter
Firmware Version V4.1.3
Firmware Hash 2fb939a1
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = FAIL - Large change in mag_field (5461.32%)
Max mag field length (27211.99) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERRs found: GCS FS_THR
Test: GPS = GOOD -
Test: IMU Mismatch = NA -
Test: Motor Balance = UNKNOWN - ‘HEXA/X’
Test: NaNs = FAIL - Found NaN in CTUN.DSAlt
Test: OpticalFlow = FAIL - ‘FLOW_FXSCALER’ not found
Test: Parameters = FAIL - ‘MAG_ENABLE’ not found
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
