I am new in the ardupilot community (67Years, since 15 years develloping and flying all kind of copters). As I am interested in software development, I downloaded from the github ArduCopter files and installed cygwin64. The Eclipse IDE is allready on my computer. The build worked fine so far. Build Finished. 0 errors, 0 warnings but I can not find the build file. (hex, elf or what ever)
In the build log I can see: the message “could not configure a C++ compiler!”
What could be wrong in my setup?
Bernhard
Some time later: something sceems to be completly wrong with my eclipse setup in combination with cygwin64
So I will drop that path and continue with WSL This step is done. Now I have installed Umbuntu and I have copied the githup ArduPilot files to my local directory.
Not sure, what dto do next. How can I connect Eclipse to Umbuntu ?
Obvious I dont need Eclipse when I am in Umbuntu.
The gcc-arm cross-compiler is here: ArduPilot firmware : /Tools/STM32-tools
So I need that file:
gcc-arm-none-eabi-10-2020-q4-major-x86_64-linux.tar.bz2
I copied it with wget to the directory TARGET_DIR. That worked
Now I hope that I can use TAR to extract it.
