What is easy way in Windows 7 to compile Source Code / build firmware for pixhawk1/px4 ?
i using description from here
http://ardupilot.org/dev/docs/building-setup-windows-eclipse.html
and configuration target compile okey:
‘configure’ finished successfully
When run target “copter” then error:
it’s strange that not atways compilation look same ( step 2/6, 4/6 or 5/6).
[4/6] Processing uavcangen: libraries/AP_UAVCAN/dsdl/ardupilot libraries/AP_UAVCAN/dsdl/com modules/uavcan/dsdl/uavcan
/bin/sh: -c: line 0: syntax error near unexpected token (' ..... ... Waf: Leaving directory
/home/Prokopcio/ardupilot/build/Pixhawk1’
Build failed
where did i make a mistake ???
or how i can build it easy with other tools ?
i try use some tools from totorials without good resultat - Eclipse+cygwin64 does the most.
for apm 3.2.1 i used arduino software without problem but now i need for HKPILOT32 board.
Can you help me ?
