Thanks for the feedback. My MissionPlanner and APM can read the log.
Will try if I can shorten it because only 7 min are of interrest.
Q_sssist_speed is 0, Q _assist_angle 30.
A the point where it did not react anymore to level or to turn left the speed was about 15 m/s.
Here two pics to show the details
It looks to me as though an elevon servo might have failed, since the vehicle doesn’t seem to be responding normally to the servo ouputs.
I can read the truncated logfile given by rollf, thanks @Rolf . What I looked at:
Airspeed is Ok but does not match GPS speed: some wind ?
Tilt servo 3 and 4 does not move in FBWB mode: OK
Power is OK
No vibration
Motor output servo 5 and 6 seems to be behave normaly
Tail motor (servo 7 or 8 ? ) does not spin during fbwb.
From time to time pitch and desired pitch does not match closely. Stability problem ? Did you check the CG?
Probably more important, your motors run very high in hover mode: around 1800 (line 485000) or 1850 (line 600000) probably too much to ensure stability. They seems to run with higher and higher pwm values as the flight goes on.
Thanks for all help.
Due to the truncated Log from Rolf, I could make a video with gauges.
@kd0aij,
I have tested all servos, now all works well.
@losawing,
Yes, there was Wind of about 3 to 4 m/s. (Fly away after touch an go)
Tail motor is on ServoOut 7
Yes, DesPitch and Pitch are not always convergent, same CG as with Tailsitter, but seems to need more P Tuning because no help from fixed Tiltmotors. but nevertheless good Transitions.
Motor Props full Trust at 1900 PWM 1620 gr each. Wing weight 2930 gr. measured on a trust stand.
PWM my increase during Flight because of sinking Voltage.
As we can see, the elevons also work in QHover (together with the tilts), why?
The quadplane controller also uses the control surfaces in VTOL modes. This is beneficial if you have some forward airspeed, and the control movements are attenuated at low airspeeds to avoid problems when moving backwards.
Here is a plot of elevon servo commands vs roll for the 3rd FBWB segment. It looks like there’s a trim issue since the elevon outputs are near max at -45 degrees roll, and close to neutral at +45 degrees.
@kd0aij
I anderstuud. Should be the same but inverse.
In level flight the elevons show 10° up. May be this explains the offset?
I checked the Elevons, no no issues.
Elevons 40° Up corresponds to 2000 PWM
Elevons 30° Down corr. to 1200 PWM.
Elevons leveled with the Wing at 1500 PWM.
Have you remarked, as first of the second issue, VIBE Z inkreased, then the Tilts move at max back (left) and 23° for (right). May be to compensate the right turn perhaps of a broken Tilt (right) due to the hard touch and go.
Hey guys!
Just a small suggestion. Can we keep this blog only for dual motor tailsitters? It’s getting all mixed up! For someone who would read discussion after a long time, it feels all chaos.
Good idea, but about 1000 Posts to late.
@kd0aij,
When hovering with vectored Yaw, the Elevons works also. But without effect in a VTOL Tri Tilt…
Do I have some Params wrong?
I think it is intentional that quadplane ailerons/elevons are active in VTOL modes.
Does that answer your question?
Sorry for the delayed reply, I’ve been vacationing lately.
Thanks for the answer.
Yes, may be has to to with the level, they move independent to the Tilt.
By the way. The rescue operation of the wing by the fire dep. was charged with 450 CHF. ~450$
1 Officer Car, 1 ladder Truck, 4 Persons, 1 hour. Same amount as one day skiing for a family in the alps.
Even if it’s a tri copter, it’s interesting. Finally what was the issue ?
First issue, not able to get out of the right turn and later spiral may be a week Pitch Tuning in FBWB.
Secon issue, crash on the roof. May be damaged at the hard touch and go before.
1/2 second bevor the Tilts move hardly the VIBE Z increased and then right turn even the Tilts wants
to turn left.
But amazing, both issues starts with turn to the right.
Perhaps other ideas when analizing the log?: https://www.magentacloud.de/share/q03kqoq-xw
Beside the broken right Tiltunit and Prop and the back Motor carrier no mechanical damage found.
Will change to BLHeli32 ESC with Telemetrie soon to get more infos.
Hello. I need some help. I have a VTOL Tailsitter with dual motors. It is a custom frame. I have only tested in the hover mode and it has some oscilations on the pitch angle that are the worst and make it crash very easy and some on the roll angle.
Is there a way to config the PID from the log file? Can anybody help me with it? I don´t know how to read it or what to look there.
Here is the link for one of the flights: https://1drv.ms/u/s!AhxpE1thbKj6v6A9seeh5sh2Rnp92Q?e=yhCp1B
Thanks a lot!
q_a_rat_pit_p parameters converts the difference between desired pitch rate and actual pitch rate into a servo throw. When this parameter is set to high you get pitch oscillation. The same for other axis. You can get oscillations also when pit_d is set to high but at 0.0036 it should be OK.
You may read several time the Q parameters list
http://ardupilot.org/plane/docs/parameters.html
until you get an idea of the role of each one.
I had error when opening your log but it seems to me you tried to fly auto mode. Is that right ?
My FX-61 phantom still has a problem getting stuck in an attitude it can’t recover from, if it pitches forward by more than 30 degrees or so it can’t pitch back up to vertical. It might not get stuck for very short back and forth movements, but as soon as it gets over 2-3m/s speed it will not be able to recover without a big throttle up. I think I understand what’s happening, the wing starts to produce lift and the centre of pressure is too far below the centre of mass (especially with swept wing), the ailerons can’t produce enough force to rotate the plane back up. I’ve read all the great information @losawing has posted, and his batwing design flies amazingly well (post 1475), but I have no experience building wings from scratch. I want to stick to non-vectored to keep weight down.
So my plan is to get another FX-61 and rotate the wings forward (remove the sweep) to make more of a plank, and not extend the ailerons but cut larger ailerons into the wing (using the wing itself, to maintain the airfoil). My question is; is this a waste of time with the FX-61 airfoil (it’s a flat bottom)? I know it would be better to use a more symmetrical airfoil with a smaller static margin like PW75.
- If the elevons are original, then they are mucht to small. 1/3 of the wing would be better.
- The CG (when vertically) has to be excactly in the line of the Motors
- I gave up my Caipirinha Tailsitter due to the verry difficult hovering. Even with larger elevons than origninal.
An airfoil that allow to reduce the static margin is a good choice. To cut foam wing core is not a big deal and to glue the wood skin I use 3M77 spray so I dont need vacuum bag. For combat wing most people just put a trammed adhesive to cover the foam core.
Nevertheless, 30° is not so bad and you can probably improve this number. As @lorbass said large elevons with ± 45° throw are mandatory. Fast and accurate servo may help too. Did you tried to move the CG backward until the FX-61 become unstable as a plane and what is the actual static margin. One solution to test the stability vs CG position is to fly the wing in manual mode but be careful, when the situation comes very bad the pixhawk is not able to recover.
