The OSD that is integrated with the Next Generation flight controllers based on STM F4 and F7 embedded processors. Search for Matek F405-Wing as one example. The OSD code displays ESC temperature, current draw, RPMs, Etc. Great to have detailed drivetrain stats in real-time in the goggles.
I just played a bit with BLHeli passthrough and latest Copter 3.6-rc11. The Pass-through mode works perfectly with a PH2.1, and an Aikon BLHeli_32 4in1 ESC.
However, is there anybody who got BLH pass through working with BLHeli_S? If I try that, there is no successful communication to the ESCs (random beeping of ESCs, random error messages of BLH suite).
I have got this working nicely, both pass through and telemetry. However I am getting a odd limit in RPM. It like I only have 10% throttle. I’m not sure if its a Arducopter setup issue or a BLHeli issue. I am using the same multistar 51A as in the demo.
At full throttle I should be at 8000 rpm or so not 500. It is not throttling up enough to take off. Have tried Dshot150 and PWM both with the same results.
The original issue was due to some odd thing that went away when I flashed master, the rpm limit was with no props on. Once I was on master I could then throttle up to full with no props but not with then I discovered the low rpm power thing so I could get full with props. Flys nicely know.
I’m still not sure what was going on originally but what ever it was has now been fixed.
@iampete how are those 51A ESC’s working out for you?
@tridge and I both had issues with them last year, and I currently have about 10 of them dead on my bench. Caused 2 crashes last season, and their telemetry or something caused my flight controller to reboot mid-flight (with no warnings or explanation in the logs).
that is worrying, that have been fine so far. I have flashed the latest blheli and they are somewhat over rated for my hex, it draws about 30A total when hovering. Although I haven’t put a huge number of hours on them yet, probably only one or two. The telemetry is very nice to have, they were the cheapest 6S esc’s I could find with it.
I don’t know what the problem is with them, this post matches my experiences with them perfectly https://www.rcgroups.com/forums/showpost.php?p=39783841&postcount=2771. Browse that thread for a few more valuable posts about them. Somewhere there is a video of the octoporter crashing during low-altitude hover.
I had about 40 hours on my first set before a crash. Then another 25 on the next set before a crash. My latest ground tests lasted about 2 hours and luckily my latest failure happend just before takeoff. I guess I was denying that it could be the ESC’s, but I just found the posts in the link above giving corroborative evidence.
I ended up testing something similar, the Airbot Wraith32 Metal v2. Same MOSFETs and driver, anyway.
It took some tweaking to get it to drive a low-kV motor, but it did have working telemetry on a PixRacer . . . for a while.
I think somehow either the PixRacer RX pin burned out, or the ESC TX pin burned out, because the telemetry stopped working. The ESC still works, though. I liked this one because I figured the current would be better calibrated thanks to the Allegro hall effect sensor.
@Naterater Have you found an ESC that seems to work reliably? Or not since the trouble with MultiStars?
I had two crashes (second one yesterday) due to midair freezed F405-Wing Controler with the 41 ampere version of this ESC associated with DSHOT + Telemetry.
This is a bigger problem than I thought. I’ll bring this on the Dev Call tonight to see if anything can be done. At minimum, a warning should be put on the Wiki.
That’s about exactly what happened to me, except both on takeoff and immediately after commanding a turn (so control surfaces were stuck at extremes). The FC won’t initialize unless it is still, so you never get servo outputs to control where it is going.
I’m so glad you guys talked this through. I bought three of the 41 amp versions, and after reading this, I bench-tested one at full throttle (33 amps) and control movements periodically, and it got somewhat hot, but lasted all the way through the first battery. Heaving a sigh of relief, I went to bed. This morning, just before the maiden, I tried a thee-minute full throttle test on the bench, and it failed. crashed my FC as well.
It’s of course in the bottom of everything.
After two midair freezings with the Turnegy MultiStar 41A BlHeli32 (occured midair without warning after 2,5h resp. 1,2 h of total flying time) I threw the multistar where it belongs into the trash and took the wraith32 metal.
After now 7.5 hours of trouble-free flight time with the Wraith and otherwise identical aircraft / electrical system (ASW 28, Dshot-150, ESC telemetry enabled, F405-Wing) I do not assume that a freezing occurs again.
