thank you Tidge and all the developers,an other leap forward for Arduplane
hi Marco, glad you like it. I donât suppose youâd like to do a video showing a fixed wing aircraft continuing to fly after a complete lockup?
Nice work @tridge! Wish my RC gear and RC brain werenât so dusty, or I would volunteer to be a crash test dummy for IWDG.
Can someone tell me/us which of the popular ChibiOS boards (eg., F405-Wing) have an IOMCU, or not?
Kelly
Hi Basti,
in my modest experience, you best take this ESC on the F-405 Wing with Dshot enabled and wait for something like this.
@Rolf donât know if iâm really confident enough for that kind of testâŚ
@tridge found it. seems itâs skipping gyro cal on reboot, however FC stays in âinitializeâ after reboot unless kept still for a couple of seconds. how is that handled inflight?
what did you find?
You would need to use mavproxy and use the lock_autopilot command
the IOMCU boards have two banks of PWM outputs (eg. âmainâ and âauxâ). For example, pixhawk, cube, CUAVv5, Pixhawk4, Pixhackv3 etc
All others have no IOMCU
Is this intended to address the recent critical service bulletin for 2019 -manufactured Cube autopilots? Or is it unrelated, as the relevant pull request is still open?
yes, it includes a simpler fix for that issue (ie. the aircraft will not crash if it loses the active IMU)
Mmmmmm⌠why not?
well, apart from the possibility that it doesnât work and your plane flies off into the sunset? that wonât happen of course
Right now the only way to induce the lockup is to send a magic mavlink command from mavproxy. I could create you a release that adds a new RC option for locking up the autopilot, so you could put it on a switch. We decided against having that in the normal releases. Would that work for you? If so, what board do you want the build for?
Some notes:
- if it is in AUTO it wonât restore the waypoint number its heading for, it would instead restart the mission
- it wonât arm on reboot, but it will allow you to arm using the normal methods while flying (eg. GCS button or rudder+throttle)
- if you are rolling/pitching rapidly when you reset then it will get confused for a few seconds (at least) and manual mode may be a good idea till it gets sorted out
The problem is the arming sequence if thereâs a rudder installed.
The auto rearm could also be dangerous but more safe in that case, what do you think of using an rc channel for auto rearm after reset? Something like âif in a high state, over 1700 uS, autorearm the system after a resetâ? Only for the testing phase, iâve 6 free rc channels, form 9 to 14.
For the build â3DR Pixhawkâ sounds good, initially I will do some bench tests.
About the risk, if the plane after the board reset work fine in full manual I think itâs minimal, the first tests would be better done in that way.
Everything depends on how many seconds after the reset the servos are back in operation.
For example an FX61 in Cruise at 70 meters AGL it could impact the ground after 6/7 seconds since the board reset.
If the procedure lasts longer it would be useless.
Thanks Marco for your amazing tests that most of Us don`t have the knowledge or courage to do but they contribute to fly safer
I have now done the plane 3.9.8 final release. In addition to the changes listed above there were 3 more changes:
- fixed the power brick2 status bit on FMUv5 boards
- added a CubeBlack specific check for failed IMUs (to address the safety bulletin)
- added logging to GPS receiver SD card in septentrio GPS modules
Happy flying!
Thanks Tridge
Really appreciate how quickly this all happened!
