I am trying to use dronekit-sitl. I ran the “simple_goto” example from dronekit (dronekit-python/simple_goto.py at master · dronekit/dronekit-python · GitHub) . However, every time I run it this is what I get on my console:
SITL already Downloaded and Extracted.
Ready to boot.
Connecting to vehicle on: tcp:127.0.0.1:5760
CRITICAL:autopilot:APM:Copter V3.3 (d6053245)
CRITICAL:autopilot:Frame: QUAD
CRITICAL:autopilot:Calibrating barometer
CRITICAL:autopilot:Initialising APM...
CRITICAL:autopilot:barometer calibration complete
CRITICAL:autopilot:GROUND START
Basic pre-arm checks
Waiting for vehicle to initialise...
Arming motors
Waiting for arming...
ERROR:autopilot:ARMING MOTORS
WARNING:dronekit:Link timeout, no heartbeat in last 5 seconds
Taking off!
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.01
Altitude: 0.02
Altitude: 0.02
Altitude: 0.02
Altitude: 0.03
ERROR:autopilot:DISARMING MOTORS
Altitude: 0.01
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.0
Altitude: 0.01
By the way, before I ran the simple_goto code, I executed this other one on another terminal
dronekit-sitl copter
And this what shows on that terminal before and during the execution of the simple_goto example:
os: linux, apm: copter, release: stable
Ready to boot.
Execute: /home/vitor/.dronekit/sitl/copter-3.3/apm --home=[blah blah blah] --model=quad -I 0
SITL-0> Started model quad at [blah blah blah] at speed 1.0
SITL-0.stderr> bind port 5760 for 0
Starting sketch 'ArduCopter'
Serial port 0 on TCP port 5760
Starting SITL input
Waiting for connection ....
bind port 5762 for 2
Serial port 2 on TCP port 5762
bind port 5763 for 3
Serial port 3 on TCP port 5763
Closed connection on serial port 0
FYI, these are the commands I ran to install things:
sudo apt-get install python3-dev python3-opencv python3-wxgtk4.0 python3-pip python3-matplotlib python3-lxml python3-pygame
pip3 install PyYAML mavproxy --user
echo "export PATH=$PATH:$HOME/.local/bin" >> ~/.bashrc
I also had to run
pip install wheel
because the installation of mavproxy was leading to an error, but after I installed ‘wheel’ it worked.
Could someone help me out, please?
